Vintage Cat 300
MSPTREX
Took me awhile to decide what I wanted to do with this one but I think I finally decided to do a retro cruiser build with it. I've had this experimental clone motor built and on the shelf for awhile so time to give it a home. I plan on doing bike mostly original with the exception of the engine and color. 20190101_151627.jpg
MSPTREX
It is a great book. I reference back to it to identify bikes and to see accessories some bikes had that are always missing.
MSPTREX
Few small things to get started. Took the original engine plate mounted kickstand off and hit it with the bead blaster before I sent it off to cambo61 to be burnished. I am sure it will look like new when it comes back.
One thing I noticed right away after setting motor on the bike was the factory predator gas cap was hitting the top of the frame. So I swapped it out with a Honda gas cap which fixed the issue of it hitting but still not enough room to remove the cap to add gas when needed. After some searching on Ebay I found an aftermarket Gx200 tank that was just what I needed. Unfortunately the black paint on the new tank doesn't match the paint on the pullstart cover. So it looks like I might have to add those to the list of things to get stripped and powder coated.
MSPTREX
Little before and after of the fenders. All I did was soak them in evaparust for about 5 days. Once a day lightly used fine steel wool to knock off the thick areas of rust . Can't believe the difference. I plan on having these rechromed when I have other parts chromed for the bike.
MSPTREX
Lots of things going on with the build. Dropped off the wheels to be powdercoated, bead blasted the fork spring, bead blasted the stars for the wheels, got my seat from member kbs8ball, got my original Cat upper fork and clutch cover decals, and then boxed up everything I am getting chromed on the bike.
Also hit up Rafa at GTS Hobbies in LA for a set of repop bottom bars as the triple tree on mine are bent up. He knocked them out the day after I called him, I will get some pics up when I get them.
