Cat engine plate
Mini Bike & Go-Kart Parts
Is it me or does everyone take a hack saw/drill/torch/grinder to these cat engine plates and they seem to crack on the front right side about 1/2 a inch in from the tubing
if you have had something like this please post before and after pictures and how or what you did to fix them thanks I welded 1 and just need to grind it down
buckeye
Well crap, I thought these Cats bikes were the "cats meow". :laugh:
Guess I have a couple of scrap pieces sitting in my garage. What ya think they weigh Derek? Scap metal is popular down this way.:laugh:
Is it me or does everyone take a hack saw/drill/torch/grinder to these cat engine plates...
Pretty common...
This was my 250 when I first got it, someone welded a bunch of crap to it and torched some holes in the engine plate:
After a little grinding and welding:
:thumbsup:
Now it's ready for a Briggs:
I wish I would have taken pics of the 400x plate when I got it from member Marshall man last year, but this one was cut way back at the chain slot and had a bunch of extra slots and the orginal slots were cut into "T" shape:
it was really bad, Almost as bad as this one that was on a duster chopper I had :grind:
I just did these plates the other day:
this one on the mickey bike was not too bad, 4 extra holes, one crack at a frame connection to the plate and one crack at an engine mount slot
Flat and round files help with squaring up the engine slots after repairs :thumbsup:
I was just told that if you clamp a piece of copper under the the holes whenyou weld Iit's easier because the copper doesn't get hot. Is that what you guys are doing?
I have a sort of tool that is basically a section of flat copper with a handle attached to. Thats what I have been using to put behind the plate as I weld. Probably something I bought at harbor freight.
If its a drilled hole I will usually take one of my stepdrills/uni-bits and redrill and it will also sort of chamfer the hole a little so you have fresh clean metal to weld to with a little angle for more surface area for the weld.
cxbra
New Member
#19
I really need to learn how to weld. Its the only thing holding me back from fabrication/metal repair and thats a BIG deal with minibikes... Great job!
#20
That's a good idea thanks
