Hi,A serious question from a newbie. It's probably the sadest question
anyone has ever asked,but I'm truely confused.I know where the governor
swingarm and fuel cut-off are,but the lever above the cut-off should be
the choke,but it's acting as the engine's throttle,so WTF? The govenor
arm is stalling the engine when moved,so why are people installing the
throttle linkage at the govenor swing arm? I'm just at the point where I
need to install my throttle linkage,but if the govenor arm is stalling the
engine,what the heck could be wrong with the engine? I did clean out
the float bowl,since it was sitting for a while and the gas crystalized around
the float,so maybe there is something clogged in the carb,but it does seam
to run good,besides running a little rich. Any help would be appreciated.
Thanks.
Thanks.
