No there is an intake manifold.. They are about 3/8 inch long plate with two bolt patterns.. one is strait accross from each other with two special screws bolted in from the back :facepalm: for the carb, then another pattern on like 45 degree angle, that bolts the intake to the motor with.. Bolt the carb to the intake, screw the intake to the motor...
screws rust a tiny bit, gotta saw the intake in half to save the carb.. :facepalm:
ALLLLLLLLLWAYYYYYYYYYYYYSSSSS when putting together an H, make sure BOTH carb screws and nuts are near perfect shape, and perfectly clean, spins on perfectly perfect.. :mellow: THAT WAY you can get your carb back off without taking off the intake.. Just shove the carb sideways and bind the bolts up to keep them from spinning.... :anon.sml:
Yes, the dreaded H40 intake manifold... NOT one of Lausons better ideas.. :doah:
the very first post actually shows the original intake still on the long block before I started
