I have a cheap max torque clutch on my bike and am having some concerns about performance. I think this clutch engages at about 2500 RPM which is causing some serious bog I think. Trying to get the right balance of gearing and stall speed for optimal performance off the line and at higher speeds. Can these clutches be adjusted? i noticed the Draggin Skin model has a variety of springs for various stall speeds. Can someone recommend a clutch, the correct stall speed and gearing for the following setup? i should also say that I am using a band brake.
Raptor 3 ported milled, etc
26mm carb
270 lift cam
heavy duty springs
12/60 gearing
Engine doesn't seem to be running out of RPM but is really sluggish off the line. I haven't been paying much attention to clutch setup; I wonder if i should be.
26mm carb
270 lift cam
heavy duty springs
12/60 gearing
