I purchased a generic Comet 20 series symmetrical TC for my 1971 HS40. I was hoping this could just bolt on and go, however, there are a couple things that I'm not sure about.
1. The inner sheave of the TC sits extremely close to the engine and damn near rubs the guard that is mounted to the engine. I can't say whether or not it actually will be an issue, but it is concerning. It looks like it might clear with the guard removed but I would really like to keep it on. Should I put some kind of washer or spacer back there to give it a little more room? If so, what should I use?
Almost on....
All the way on, and close to rubbing....
2. This TC came with a bolt and end keeper that is too small for the correct size bolt. Basically, the bolt is useless and the end keeper plate does not work with the larger correct size bolt to keep it on the crank shaft. I either need to buy the correct "end keeper" that has a bore big enough for the correct size bolt OR I need to drill out the current one to make it work.
The "End keeper"
The bolts
The small bolt that doesn't fasten to the crankshaft
The larger correct bolt, not working with the end keeper
I'm sure someone else has run in to these issues before. Any help is greatly appreciated.
Thank you
Mike
Almost on....
The "End keeper"
The bolts
Thank you
Mike
