Alright, problem solved. Congratulations to jeep2003 for the correct diagnosis, with an assist to james c. One of the 2 springs
was off (jeep)because it had broken (james). One of the end loops was off. The spring ended up in the outer corner of the outside plate and was keeping the inner plate at least 5/16" out from fully retracted. I bent another coil out for a new hook and
voila!
I cleaned everything up and put some Dri-Slide on the areas specified. Now it retracts most of the way when the engine slows down (without the belt on). HOWEVER, even with it opening all the way, the 3/4" wide belt would not bottom in the pulley, so it still wouldn't work. I had to go retrieve the 5/8"-wide Comet belt that I'd returned before. It works fine (at least on jackstands - it's snowing here and I don't feel like installing the ski:wink
, so I guess the driver isn't a 30-series?
The belt could maybe stand to be a tad shorter (it's the same length as the 203589A), as it doesn't quite open the front pulley all the way (but close) and has more slack than absolutely necessary when disengaged. But it will suffice for all the use this thing's going to get!
In fact, my sister's talking about selling it. Any ideas on a ballpark value for a non-street-legal Tecumseh-engined Tri-Sport in pretty good shape? (Especially compared to anything I've been able to find for sale in the last few weeks!) The red fiberglass body is crack-free, if somewhat weathered (whitish/cloudy compared to under the seat). The original seat had some seams coming apart and is off the trike in the pics I'm about to post.
The chrome has some blistering (all over) and peeling (on the rack above the engine) but should clean up to look
halfway decent. Tires are great - very little wear and no cracking. And it has the ski. Is the ski something that should be sold separately, or does it increase the value of the trike more being with it? I have to get going; here are the pics of it:
