This is my first TC I have ever seen or worked with so I am still learning here. The pieces all look to be in prety good condition to me. The springs have been in a round position for almost 30 years so they have kinda took that shape. Do I "REALLY" need to replace them? I am trying to not take out a second morgage to finish this project. I still have alot of parts I know for sure I am going to have to buy but I do want it to be done right. I think this is a CAT99 but I am not 100% sure. I do know it was made in or before 1986.
This is the belt that came with the TC. The guy said he had been running it for the last 6 months before he took the motor off to rebuild it so I know the belt was working. May not be the correct belt but it must be close.
I tried to measure and get a good picture of everything.
From looking at pictures of new ones online, the weight doesn't look to be wore much to me but I will let the professionals decide.
I went here to ID it - How To Identify Comet Torque Converters and it said if it was 5/8" then it was a CAT99 but I got more like 1/2" on the opening and the center shaft. When I put the belt on it with it closed, the top of the 5/8" belt is definitely wider than the opening. I seen on that site where it said there were washers used on some 5/8" ones to make them 3/4". I didn't know if I needed to add washers to make sure it was 5/8" or leave it alone. It doesn't look like anything is wore down to make it that way - it looks like it has always been 1/2"ish. I also didn't want to change the size of the drive and throw the driver off too.
You can see here that 5/8" is wider than the opening when fully closed.
Here is the space / void I asked about in my first post.
I found some drivers that came with what they call a pilot washer so I was curious if mine was missing this.
Driver 3/4" bore,Max-Torque
The guy I got it from said he does not ever remember one here. He also said I have all the parts to it and one was not with it. The few I seen online was only about 2% of all I seen. Half of them were for 1" too. Also looking at the original manual from Manco for this kart, it does not show nothing but a screw, flat washer, and lock washer. This is what came with it. I don't think I need the other type washer I was asking about here...
http://www.oldminibikes.com/forum/e...p-installing-torque-converter-drive-unit.html
The screw, lock washer, and flat washer seem to work fine.
My driven part I am still checking out. I do know it uses buttons like the 40 series does and they are white. I think it also has a red spring on it. Its rusted now but the guy I got it from said he thinks it was red too.
Where is the cheapest place to get the lube for these? I do not want to pay $25 plus $10 shipping for a couple sprays of lube. Is there somewhere like Lowes, Home Depot, Ace, Wal-Mart, Ebay, Target, Tractor Supply, Harbor Freight, Northern Tool, or somewhere like that I can pick up a tube / can for like $5?
Will my garter springs be ok and work like they are supose to? If not where is the cheapest place with shipping to get some?
I know I will need 3 new wear buttons - 40 series and a red or green driven spring. Who has these the cheapest with shipping?
I may also need a bushing - mine has a small crack but it looks usable right now. Cheapest with shipping?
Thanks in advance for your help.
