So started with a doodle bug and basically pictures speak for themselves selves... Tryed taking pictures as much as I could but a few were lost from switching phones ... I later sectioned the frame about a 1.5" so it wasn't soo high and got the top tubes closer to the motor .. Front tire is off a scooter and rear tire is from a kart .
The motor is a predator 212 old style all that was used was block and crank. After that mini bike Charles ported a head and sent a custom grind cam. Agk billet rod, agk flywheel and 28mm mikuni was in store for the motor. Later I got with Robertson's kart pipes for a 28mm inside diameter pipe to get some flow going.
Motor
Mini Drag Bike Charles hooked me up with a isky custom grind cam and a fully ported and valves head. 32/28 valves.. Beautiful work.
Motor
