Installation--- Put bearings in the fridge for a few hours, shrinks them before installation. Conversely , put empty bearing mount in hot sun or hot hairdryer heat to expand the opening.
I prefer OOO or OOOO steel wool to clean.
Sometimes a super light coating of Never-Seez product if I think they will need removal again.
REMOVAL aid-----3-cycles of gentle heat and cooling using penetrating lube (PB Blaster, Kroil , etc) before attempting use of force.
THEN, gently heat outer 'boss' area that holds bearing ..... then use a chunk of ice (or better dry ice) OR the cold air spray (used to clean computer keyboards) directly onto the actual bearing.
Tap out, or pull while chilled using proper tool.
