I've disassembled the engine and stripped off both the original paint, and the "Ebay Seller Rattle Can paint. I use paint stripper, 3M pads, and elbow grease. No blasting is used on my bikes, or engines.
Once the crankshaft had been removed, I decided it would be prudent to replace all bearings and seals. The PTO bearing needs to be pressed out, or pulled. I seated the crank in a jig and tapped the bearing off with a cold chisel. This area of the crank will be machined down to accept the new bearing without applying pressure. It is held in place with a C-clip.
The PTO Bearing Part Number is 127910-2, and the PTO Seal is Part Number 31146.
The magneto side needle bearing and seal will also be replaced. It is necessary to heat the aluminum to 150F to facilitate this. The Magneto side Needle Bearing, is a Torrington, Part Number B-126, and the Magneto side Seal is Part Number 2770146-1.
Member OND gives a good write up on some of these aspects in his thread
here as far as tearing these down and removing C clips and rod bearings.
I have been trying to come up with paint designs for the engine. I am not a fan of polishing aluminum, because no matter what, at some point, you are going to be polishing it again, even though it looks stunning. Clear coat will dull the polished aluminum, and paint looks like....paint. This is a US Motor product, not a West Bend, Chrysler Power Bee, etc. So it was painted silver with a black recoil right out of a Tecumseh.
But at least I am THINKING about it, LOL. Also wondering if I should go with a Black Mamba cam, or a CL-1, and just use 18 LB valve springs. :innocent:
Almost forgot- Louie Figone has exchanged countless emails with me on various aspects of this. He is setting the carb pop off pressure for me as well. Should be good, as I used original spring, but nice to have a master look at that carb for me.
