Sorry, this is a newb question, but I could not find an exact answer. I am not running in a class, just a yard kart at home.
My setup-
6.5hp clone
Flat top piston
K+N filter
Billet rod
Aluminium flywheel
BSP-1 cam
Wiener Pipe + Muffler (will possibly change)
My questions-
1. My piston is approx. 0.035 in the hole. I was planning to mill it so I had .015 pop up, and use a gx160 head gasket, is this a good idea?
2. I was also planning to mill my stock 22cc head by .050. This will give me approx. 11:1 compression ratio. I am running on pump gas, can/ should I go higher? I was also going to remove any rough casting etc.
3. I have a BSP-1 cam, and was planning to shave the base circle with a toolpost grinder on a lathe. What cam lift would be good with my setup?
4. What valve springs should I use? I would like 6-6500 rpm if possible? I was thinking 14lb gx140, 16lb gx160 g4's or 18lb g200's?
5. Would I benefit at all from a 22mm mikuni or gx390 carb?
Thanks,
Rob
My setup-
6.5hp clone
Flat top piston
K+N filter
Billet rod
Aluminium flywheel
BSP-1 cam
My questions-
Thanks,
Rob
