Help with 1" Twist Throttle
I have a 1" twist throttle that looks identical to the one sold on OldMiniBikes's site. We cannot get it to turn smoothly for anything. It drags badly. Any Ideas?
I had the same problem a few weeks ago ~ the bike started and got stuck at about 1/2 throttle ~ it did a donut in the garage and threw me off. Mine is an aluminum tube Chinese made (new) replacement throttle that had to be de-burred and sanded smooth then lubed so the return spring would have enough strength to move it to idle position. Yours might need the same attention.
I had a problem like this last year with a 1" set also,found the inside is not round ,slight egg shape on inside of the aluminum,I wraped some sandpaper around a rat tail file and put it in a drill for acouple minutes,seemed to open it up enough to move freely.
Me too, on a plastic tube style. Had to use a Dremel tool and remove a slight bit of material on the wider sides of the "egg" shape.
Michael
george3
egg shaped throttles. LOL Get what you pay for. Un-clamp the chrome clamp and see if the throttle tube turns free. Go From there.
Bikerscum
I had that problem with the 7/8 OldMiniBikes setup. Nothing seemed to help. Then I made this...
Giving the cable a straight shot into the housing and not rubbing on metal made all the difference in the world.... the return spring makes it snap back to the off position now.
:scooter:
I've bought 2 sets of th OldMiniBikes 1" English made ones and neither have a spring return. neither turn well freely is this normal
Or I did I get bad ones? I figured I would just fart about to make them twist better ad hoped that the heavier spring I've put on the motor end would pull it back.
Buck, what is the point in having that little clip thingy you say to get rid of? I agree that it does not seem like it does any thing really but would just like to know what the intent of that part it.
Yes, I've tried dremeling it out and it helped a little bit. I also made sure the grip wasn't rubbing and it was not touching the end of the bar and it still drags...thinking of just going with the brake lever throttle idea.
I would go over every part of the throttle tube with 1000grit including the part that fits into the corridor (the part that actually holds the throttle end) also make sure your (not) using "wd40" thats the worst thing you could do. I use rem oil and it works very well.
:scooter:
Interesting solution- what is that made out of and what did you have to do to it for it to work?
Michael
Bikerscum
It's made of delrin. Slotted on the bottom side you can't see so it slips over the cable, counterbored on the entrance side for the cable sheath to sit in, stepped on the exit side to fit in the throttle housing. A hole thru for the cable itself to go thru.
The problem I had was that the cable entered the housing at an angle, & rubbed on everything along the way. This gives it a straight shot in, & if anything the cable only rubs on slippery delrin.
If you have a sticky throttle problem, try holding the cable so as to give it a straight shot in, you might be surprised. Mine now feels just like a MC throttle.
I made it on my mini lathe but it could easily be made with a drill press & hand tools.
:grind:
#19
I had this problem AFTER I reinstalled a twist grip on a bike I painted, that worked fine before i took it off. Turns out like others said the bar was too tight against the plastic tube for the spring on the throttle to pull back. I did take care not to push it all the way onto the fork but appently it wasn't enough as once everything was tightened down the housing was still pulling the plastic tube against the fork. I wound up backing the screws out just a tad and gently tapping the whole assembly outward from the fork, tightening and checking for free movement. Took about 2 or 3 tries till I got it right. Most surprising was that there was a line in the new paint where I first though it was set correctly and once I found the right "spot" I was about an eighth inch out from there. As others stated the plastic is cheap and has alot of slop, and when you tighten down it seemed (for me anyway) to clamp everything down better and pull the plastic inward.
Just to clarify - my friction point was between the end of the bar and the inside end of a solid tube, the tube spun freely on the painted bar when not in the assembly. I also had a hollow tube and had to take care to install that so that when tightened (and the tube pulled inward slightly) the bar did not protrude out past the end of the tube - thus the installed grip would then bind. Sorry I wish I would have taken pictures to explain better.
Kacz
