I am doing some mods on a baja heat. i have the Baja clone 6.5hp. It has a working lighting coil. the coils under the flywheel are 2 crescent shaped wireclusters under the proper magnet flywheel. I wanted to run one of the wires to charge a battery (I know i need diode...) and the other to the headlight (AC). When I test the 2 wires coming off the coil into a plug (they are both both blue if makes any dif.) that goes to headlight plug --while engine is running i get approx 10+- volts. Test done with multimeter black lead to one and red to the other. If i reverse the leads from the multimeter I get the same reading. To me this means that the power does not generate unless both wires are connected. What am I missing shouldn't one wire be a negative and one be a positive if they are used to power a bulb? If i test one coil wire with test lead and other test lead to engine ground --reading is 0 and vice versa. The headlight plug is plugged directly into both of these wires coming from the lighting coil. It seems that the two wires should be both A/C like on a riding mower. But they give readings the same with the mulitmeter hooked up either way as long as both wires are connected to leads. Any explanation for this? or too confusing?
