OK, I've got a Fantic Broncco that was previously owned by a complete freaking nimrod. The bike is Italian so all the original hardware is metric and the yuts drilled out a bunch of the holes for standard hardware! This included the swing arm mount holes on the frame.
I'm swapping out the butchered swing arm and of course, the 12mm hole has been drilled out to 1/2". Better yet, I found that the "bolt" was actually a 1/2" ALUMINUM ROD that was threaded on both ends. Its not a huge difference (about .7mm), but it creates enough slop that I've got to do something. Here's my options that I can think of:
1) Drill out the new swing arm to 1/2" and just accept that the bolt will be wrong (though I will make sure that its STEEL!)
2) Cut off the mount plates, make proper ones and weld them on....yeah right. Not happening unless I get a laser cutter and alot more time
3) Find a way to shrink the hole. I was thining about making a bushing out of the right thickness sheet metal, tack it in and grind smooth
What do you guys think? I'm leaning toward trying #3 and going to #1 if it doesn't work
