Figured you guys are the best to ask about HS40 motors so here it is...
Picked up a old HS40 that looked to be rebuilt by the massive patch of JB weld right under the fuel tank on the block! Anyway, I rebuilt the carb, new fuel lines, filter and so forth. Ran great!!!! But then it wouldn't....
Long story short, I pulled the head and found that when on the compression stroke the exhaust valve lifts ever so slightly off the seat wobbles a touch then reseats back about half an inch before the piston hits TDC. strange right?
So what can cause the exhaust cam to lift off the seat during the compression stroke? it seats fine when the piston is at BDC but right in the middle of TDC and BDC it lifts off the seat by a 1/16th or so!
Retarded issue as compression reads 95-100PSI but takes a few revolutions to get there. Looking like good compression but it's not due to the exhaust valve lifting off the seat.
