I bought this HS50 from a guy.....
That told me it was NOS and never had gas /oil in it. I do believe him because I'm taring it apart and there are NO SIGNS of it ever being ran. There's also NO SIGNS of any numbers to tell what year it is :mad2: The owner had ground off the numbers on the fan shourd and just left the :censure: "HS50" there. Is there any other way to find the model year of this engine? I have spent a few hours here searching and came up with nothing. I will need a complete gasket/seal set for this engine do to the Performance modifications that I'm going to do to it.
This engine will be going in my Chopper, and I want to put in ARC Rod #6282 in it also, I would need to know what parts I have to get a hold of to make this HS50 have lights and a aluminum flywheel due to the removal of the governor. A Cam/valve springs will also be added to the mix to make this thing as noisey as possible :thumbsup:..... Here's some pictures of the engine and maybe someone can help me out.....
..... with all of the parts taken off that I won't be using (carb,tank & exhaust)
I just couldn't help myself and stick these on for a look see.....
Thanks for ANY help that you can give me on my quest to achieve my goals here with this engine. On a parting note, what Tecumseh parts web site is the best.
BC1500 DAVE :thumbsup:
