another problem i have with set screws is in an effort to make them really tight, the set screw hex hole rounds. especially if your allen wrench is not in perfect condition. and once that happens, you're screwed. set screws are hardened, so you really can't drill them out. and now you can't get the jackshaft assembly apart. other than to ride the bike until the jackshaft falls apart. ha! it's a hot mess.
i'm still struggling with why any one would want to use set screws??? i mean we all stopped using them on clutches like a zillion years ago. and instead drill/tap the crankshaft and use a bolt. what is the up side to set screws? that they're the lazy way to attach a sprocket to a jackshaft?? so you all are telling me that set screws are no good for your clutch, but it's Ok for your jackshaft?? yea right, or Mr.Denial, you go with that flawed lazy thinking... you spend all this time/energy hopping up your engine, and then put it all together in a bike with set screws? Really??? chain only as strong as the weakest link....
