I need a stiff TAV-30 Driven spring.
Where on the interweb sells stiff springs that will fit ? Must be at least twice as stiff as the yellow spring. I'll even cut on it to shorten it if i need to.
Let me know, I really like my low to mid range power.
yes, beltpalace is good. I went to the green spring hole #2, but it
wanted to stay too long and also wanted to shift back down too
quickly on deceleration. Hole 1 was the ticket..beltpalace also has
a Bando belt which is the best I've come across.
MB165
have you considered running tighter driver springs? is there room for a inner, compression spring? I assume your trying to delay the shift?
