Tech Support @ Harbor Freight,
I recently made my first HB purchase, a predator 212cc that I intended to modify. After a good deal of disassemble, I examined the inside crankcase. There are some casting marks between the flywheel bearing and the cylinder, that were inspected and apparently approved as within specifications. However, I am not satisfied.
Because I intend to use the engine for purposes other than what is considered "normal" operation, I can't use one with this type of fault. The amount of stress loaded on the crankshaft would surely result in failure. Please see the picture. I just can't use this block.
I want to return it for a replacement, even though I've disassembled it, and begun to modify the stock engine. However, I feel a little apprehensive about asking my local store manager to assist me without fully informing you of the state of the product and how it came to be, i.e. I need to check these things before putting the engine to service. Lucky I did, there are no casting marks on the outside. But, the inside marks would cause stress peaks that would eventually give way. I would like your approval to return this engine to my local store.
I don't have the invoice, so I called customer service and she graciously said she'd send one to me right away. I'm hoping you respond in like manor and we can resolve this problem quickly.
Thank You
KeithDoerr@ymail.com
will be returning predator 212cc engine to:
Harbor Freight Tools
2399 Ellsworth Road
Ypsilanti, MI 48197
(734) 434-2402
