Nova 780 serial number 106. Worm gear drive via proprietary TAV, 7 HP Briggs not original, missing parts.
When we get an engine missing the air filter, this should be our first clue. Rod bearing was so ground down, the bolts were finger tight.
Bad rod, crank, bore, and numerous stripped threads on block along with missing shroud mount lug, welded on shroud, and several missing pieces. This motor is scrap.
