largest emulsion tube causing bogging down, how can I fix?
I installed a predator 212 on a go kart project I'm working on and I got a stage one upgrade kit which includes 36 & 37 jets and a larger emulsion tube, when I installed the air filter kit it was so lean it wouldn't start so i swapped in the 36 jet and it ran good, then I swapped in the larger emulsion tube with the 36 jet and it ran but bogged down pretty bad, so I put the stock emulsion tube back in and I'm using the 37 jet and it's running good again, how can I use the larger emulsion tube with the larger jets and it not bog down? I haven't installed the timing advance key yet will that help? I'm still pretty new to small engines
