Hi again. Please refer to my other thread in this forum as to why my Baja's stock 200cc engine is not currently running... Hopefully two of my dad's mechanic friends can figure it out soon... I spoke briefly with several small engine repair shops in my area and they don't do work on clones...
One person I spoke to suggested something that no one else thought of yet: maybe the flywheel side end bearing in the engine case was somehow damaged when I first removed the flywheel....
Anyway, I am not giving up that someone will figure out how to get the stock motor running again. However, I have noticed that my local Harbor Freight has in stock the 212cc Predator engine: 6.5 HP (212cc) OHV Horizontal Shaft Gas Engine EPA
I searched high and low on the web and could not find the answer to my main concern if I have to buy one of these to install in my bike: What is to be done about the fact that the stock motor has about an inch long threaded shaft at the end of the engine's output shaft???? This shaft was obviously where the castle nut and cotter pin were used to secure the clutch onto the output shaft...
Pics below of the output shaft of my stock engine for clarity:
The predator engine does not have this threaded shaft segment....
If anything, and we never can get the stock engine running again, I've learned a lot thus far.
