My buddy has been wanting me to chop a bike up for him, so he bought this run of the mill late model Manco streaker off another buddy and told me to give it a "nip and tuck". Just kinda freestyling it, no real set plan other than he wants it as low as it can go.
This is what I got done today:
I knocked about 3 inches out of the frame uprights using a 3hp briggs as a guide (should have taken a before shot, but if you've owned a streaker you can probably tell its chopped :wink
I was going to just use the sections I cut out to stretch the frame but I actually cut it twice so I dug out a donor frame I have been cutting sections and tabs off off for projects and cut out four 4" lengths of tube, sleeved them, and lopped the frame in half:
He actually wants it lower than this, but wants 6" tires front and rear:
Not gonna happen I say, I dont want to mess with the headtube. So its probably either gonna sit about this high in the pic above or its getting a 4" wheel tire in the front. Yes scrub brake is coming off and the rear wheel will be mounted outside the frame pretty much where its at in the pic. there should still be enough room to fit a clone in with tank etc.. removed. If thats done I would like to see the engine plate centers and a jacksaft installed, but he says he will be happy with a 3.5hp and this is how low he wanted it.
