thanks everyone, its getting there! Greg, yes that little 3hp shined up nicely I'm glad to hear you guys are riding up there, your new house/Neighborhood looked pretty fancy schmancy, I figured you guys were done for far as riding goes :laugh:
Lets hope the sticker comes off and leaves the paint intact when the new, more correct one get s done! :blink: chain lineup is incorrect as of now, I used the spacer that were with the wheels, the sprocket that came with that set though was one of those older Azusa rivet sprockets so it sat closer to the wheel. I will have to take the wheel back apart and use shorter spacers to get it in closer as I want to keep the wheel centered. I messed up on that, when I threw that together for a quick mock up it lined up with the chain wear marks on the frame (didn't use an engine)...I realize now it lined up because they had drilled 4 new holes in the engine plate and moved whatever engine they used over a little. :doah: At least is only a matter of some shorter spacers for the sprocket!
Very nice Markus! That M/T sticker looks great too! The rear wheel looks nicely centered in the frame? That is often a problem with the earlier frame styles. Did you do some adjusting to get the engine, clutch, chain, sprockets to line up?
