help needed
Right now I'm having a problem with the animal, it pulls hard from idle to about 4k and then it is flat. I have to hold it wide open and long to reach 4500 rpm. That is on flat road. The bike and I together weigh 240lbs. It has a tav2(10teeth)-jack shaft input 11 teeth-JS out 16 - rear sprocket 56 teeth and an 11" tire. I changed the carb for a bigger one pz 26 (120 main, 40 pilot), nothing changed. Could it be the cam? This is a real briggs animal engine that they say it should reach 7800 rpm. Any thoughts?
Oz
