I sale the 22mm carb, intake, rockers, and I even have a Zama/tillotson carb.
The 22mm carb works perfect on the 6.5hp version clone. That's what most of the kids run, because they get them from me. I get the rockers from a stock class cheater I can't name. But they make your motor sound a bit radical. They really help being that Hondas, and clones only have a .227" max cam lift. Which is way smaller then the briggs 6.5hp .255" lift.
I can tell you how to advance the timing, but if you don't have the correct tools you might screw it up. You can always buy a offset key that has already been cut. NR-Racing sells a lot of parts, but there extremely pricey.
You can get the tillotson carbs brand new from E.C. but they are a bit expensive. Usually for the carb, intake, and velocity stack it's around $160. Two models work great HL357A, and HL334wx. It's best to find one used, or new at a deal. The most expensive thing you will need is a billet rod for safety.
