Finally getting around to making some of the changes I had planned. I have lengthened the wheel base by extending the rear out 7" and lowered the rear end by almost 4 inches. Still thinking about raking the front end a few degrees. Did a physical measurement of the trail and it looks to be around 4 inches. The stock rake is somewhere around 30ish degrees. If I rake it I will have to make longer forks as the frame is less than 3 inches off the ground in the front.
I started tearing down the motor. I need to do an in the hole measurement and then I can start ordering parts. I bought a tach and did some high speed runs to see what the rpms were before mods. The new tach showed 5800 rpms, the goal is 7000.
