Brian it's going on the rupp that I'am bringing to windber . But for windber the rupp will run Doug's predator . We are just testing the predator on my bike , it will eventually go on another rupp that I'am helping Doug build .
Looks great.
That's the final look I'm going for on my DB Hemi install.
I see you also removed the air shroud from the engine for a cleaner look. Any problems with that?
Also have any of you guys gone so far as to cut off the old gas tank mounting brackets to really clean up the looks?
I've had this 24 mm mikuni flat slide sitting on the bench for awhile now it's my brother Jesse's . So today I thought I would try it on my motor . I had a manifold stub laying around so all I needed was a piece of 1 1/4 radiator hose with a 90 degree bend in it . The carb works good but I this I want to try some bigger jets .
