oil crank seal replacement
How do I change the oil seal on the side of the block where the crank sticks through? the bearing is good so id rather not mess with it, but the seal is bad. got a new one ready to go. the block is all tore down.
CarPlayLB
On Predator can't you just pull it out from the PTO side? Use a hook and destroy it to remove it? I think it is an easy slip fit...just yank it!
Just pulls out, and push the new in the same way the old one came out. ..I would oil the Inner lip of the seal before Installing It.
