Hello new to this forum, I have a few quick questions. I bought a billet rod from ARC and want to install new rings also, well I'm not sure if I have the 1mm or the 1.5 mm thick rings. Then I noticed the low tension rings and wanted to know how thick those are if I can use them in my motor?. I pulled off the head to look at the top of the piston, it's not 100% flat it dips in a lil about 1mm. It is a blue harbor freight greyhound 6.5 hp. I work alot and dont have much personel time so I'm tyring to find out without taking off the rod and piston, order the parts, wait untill they come and have parts lying around untill I get the time it install them.
my next question is while searching for an answer I've read about installing exhaust valve retainer and lash cap on the intake. So yesterday I went and bought some and put them on this morning and noticed that the intake valve tip is longer then the exhaust, so the lash cap does not sit all the way in the retainer. I have 18lb springs so I don't think I'll need a shim, but do I need to file the tip of the intake valve down so the lash cap is almost flush with the retainer like the exhaust side is?
My last question is if this flywheel is good enough I'm a family man so I have my priorities but I take my kids out when I go out on my go kart, and dont want my fw exploding and smacking us up side the head. my governer is taken out. PVL Flywheel for Clone
thanks in advance
thanks in advance
