Ok hello to you all. this is my first post. I consider myself a very good home mech. I have pulled trans and engines, BUT OMG this pred engine is driving me nuts.
history:
I got a go cart from a friend, for a father son project. It has a pred 212 engine. It fires up on the first few pulls, but would only run when in the full choke position, even with the throttle wide open, but slide it into the run position and spit, spit, DIE...so I pulled of the carb and cleaned it the best I could. Put it back on and Now it runs fine in the run position idles good to THAT PROBLEM SOLVED
, but the moment you press the peddle (or give it gas) the spit, spit DIE problem is back.. What the heck. The carb on it is not Ajustable. so whats going on.
Secondly, when its idling I feel a lot of air flow coming from the location between the OHV cover and the carb. Is this normal.the air flow is STRONG ,but not hot air. its like a small computer fan.the air is coming from the red area and is strongest at the location between the value cover and carb
history:
