I have a Predator 212 Hemi. I started looking for a cam thread but didn't find one.
What is the progression from stock to wild as far as cams go? Is there a chart that shows lift and duration of all the cams?
How much cam you safely run in a stock 212 Hemi? I mean using stock piston, stock rod, stock head, stock rockers and springs, stock flywheel etc. I have the stock carb but bought a jet kit, carb adapter, air filter and have a header pipe.
How much hp do you gain going one cam up from the stock cam?
Thanks
Danford1
Thanks
Danford1
