Save your money up to get it right the 1st time. There's other things you will need, tools, learn how to set those important clearances, set valve spring install height, set ignition timing, learn more about cam timing (valve events) how, and when they make power. Porting heads and other small things that most overlook and think are not necessary.
The stock flat top piston from the pred 212 hemi will be a very nice improvement in the non hemi. It will bump up the CR to 10:1, with what you already have and that's a very noticeable increase in power, even with the stock cam.
A performance coil that dont retard ignition timing in the upper rpm, and will increase acceleration. I use dover coils, they work. Screw those stock coils, they go in the trash next to that mod2 cam, lol.
You doing a really good job and going the right direction, jus keep it up.
Here's that coil. Dover Power has got really good products and very easy to deal with, down to earth no non sense, good people.
Get some of their magnetic drain plugs too, they work good, all my builds get em. They will have that flat top and ring set for you too.
http://www.doverpoweronlinestore.com/catalog/item/9100750/10483555.htm
http://www.doverpoweronlinestore.com/catalog/item/8223859/10335682.htm
