I talked to russ about the safe issue regarding the arc adapter. i told him the air bleed on the back of the 390 carb was un able to vent with just the adapter.... you can do two things... One is run a insulator...and you still at a 15 deg angle, or you can jb weld the back of the carb, and drill the air bleed on top/side of carb with a small nipple to vent...this will allow no insulator just gaskets and give the true stock appearing look. If you get nr racings 390 to gx200 adaptor it all ready had the insulators vent areas built in...and will sit at the angle you need... if you go this route the carb is nowhere near as aggressive as the short arc adapter..it feel like a 22mm at best... the first way at the 15 angle did idle and surge...but as soon as you got full throttle it was like warp speed:laugh:...just food for thought.
I had ordered the short adapter shortly after picking the carb, because after research, learned it was apparently better performing than the longer one... and figured it was $13 more at NRRacing for a reason... was making an order (5th or 6th) through ARC and threw it in the kart... when talked to Russell he asked me if i had one, i told him yes the arc and he told me what to do if i had the issue... your post clears this info up, as i forgot exactly what he said...
