ok I have built another 212cc I have got a aluminum flywheel on it haven't put rod or nothing in it just have removed the Gov. and have installed a gx390 carb but before I put the gx390 carb on there I had this issue I got now.
when Im at a dead stop in I floor it its takes of pretty good but after that its like its dragging a car in bogs down an shakes bad in then it picks up again straightens out an halls ass down the road. Its not the clutch slipping either its just like I said its like its trying to pull a car
could this b the 8 degree timing flywheel to much timing to I need to buy a 2 degree key in time it back or not enough fuel. Or do I need to back off the timing but it did this with the factory carb. also I have open air filter in a j pipe on it coil gap is at 40/50 I really cant remember is this a timing issue
