Hi,
I plan on taking the governor off my predator 212 and rebuilding the engine with new parts. Application: baja warrior
These are the items I am getting: ARC rod, ARC flywheel, BP2 Grind Predator Core Dyno Cam, #26 springs, HI COMP 14cc heads, new gaskets and mikuni carb.
Am I missing anything to my engine safe?
Will the stock tank suffice, or should I get an aftermarket tank?
How big of a difference does a high flow header make? Should I invest in a new exhaust instead of using the stock one?
Thanks in advance!
Thanks in advance!
