Need a better exhaust for the atlas before painting the 2nd engine white (going with a briggs), In the passed I cut up some free bikes I got from CL and the tubing comes in handy for stock.
As you can see the tubing I'm using is already dilled and tapped for a water bottle. I'm using these holes for a mount and the other a screw for the muffler (so it can be changed)
I installed the muffler tight and drilled and tapped a hole in it so it wont turn or come loose.
Very fast, simple and clean, all I have to do now is make a bracket.
It sounds good, runs good, and doesn't piss off the neighbors.
