i was just wondering too how that whole setup was going to work for you? the only two isky cams i know that tim makes is one that turns 8500 rpm's and the other i believe is around 7000? i would have to double check on that one. both of them cams are way too much for that little flathead and setup that you are using. i don't think you will be happy with it and it could be a fighting battle with that carb.
if you are just running a clutch to rear sprocket you never really going to to feel the power. the gearing won't be correct. you would really need a jackshaft and on that bike build i don't think you want to go that route?
your almost better going with a newer stock tecumseh cam with the spring/arm compression relief and little stiffer spring,advance the timing and install a 2500 stall spring in your clutch. mount a rupp style adjustable jet and idle carb(new replacement) or maybe a small mikuni carb. you should be able to pull rpm's up to 4500+ or so with the factory gearing. 10tt clutch....maybe with just little bigger rear sprocket...
looks like you got most of the stuff done and looks like your ready to fire it up. just try it with the stuff you got now and see how you like it first before changing anything.
just keep us posted,bike looking nice......:thumbsup:
