I'm putting Kawasaki calipers on mine, I'll have to make a flat plate to bolt to the frame mount and use 2 spacers between each caliper and the new plate.. I also bout some 1/8npt x 10mm adapters so I can screw compression fittings in calipers for the brake lines...The 10mm thread isn't quite the right pitch for the caliper so I coated it with red locktite and screwed in down tight and with the sealing washer it should be fine..
