They are a close copy to the original 1969 Roadster, with some very slight improvements; obviously they use modern day clutch technology, but with the same second gear shift point! The distance between 1st and 2nd gear has been opened up slightly, so the master links will no longer rub together. Lastly, the key is not built into the sleeve like the original one, it is a separate part.
All of the original parts from a 1969 Roadster will interchange with this reproduction set up. The 2nd gear clutch and drive sprocket use a roll pin the secure them just like the original.
The set up will come completely assembled on the jackshaft, with both clutches, and all hardware and installation instructions. The only thing the buyer will have to supply is the two out side frame 5/8 bearings, and the two chains.
