If you add smaller tires (than stock) will it raise or lower your gear ratio. It seems like an easy question off the bat (larger tires = more speed). I know that on a skateboard bigger wheels make a big difference downhill. But see, a skateboard isnt limited by factors such as engine RPM (biggest one) and is able to in a sence "rev" as high as it wants (the wheel bearings being the only factor). Yes, I have been smoking this morning :wink:
So is it the same for the minibike? Bigger wheels = lower gear ratio (higher top speed)?
