I have a hustler pr
Jim I have a 71 hustler project that I'm rebuilding also and just compared the chain adjusters for that to the MTDs and they were the same , The axle bolt hole may be slightly bigger on the MTD but they are ovaled a bit so I don't know if the hole is correct size but it will work on the MTDs even if the hole has to be reemed a bit, BWM shows the 70-76 being part#15250 what is the difference between that and part #13788 for the 69, possibly the size of the hole or is it a different size adjuster all together? I figure I might as well get a set for my MTD project now that the conversation is open and just want to order the correct one's and pass on the info to anyone else that can use some on the MTDs, thank you
