I know a lot of you guys are running flat head briggs 3.5hp motor's well if you have one, it has to be the block with two bolts too mount on the coil, this wont work on the older blocks with 4 bolts,
here is a tip for you guys with or with out points,
change over the old steel cast flywheel, too a lighter aluminum flywheel, from a flat head briggs 3.5hp push mower & use the newer solid state coil from the push mower,
the newer solid state coil has just one wire hook up, & it is the kill wire, ground it out & the motor wont start..
If your motor had points leave them in there, & just take out the wire going to the condenser from the old points coil, i just cut them,
make sure you get the flywheel tight & get it all back together & you will notice you freed up some power, the motor will run & start much better
