Built a drift trike but having issues with standard centrifugal clutches burning up. Decided to go with a TC but current frame design prohibits normal mounting. Is it possible to mount the driven gear on the outside of the jackshaft? If so, will the bearing be able to withstand the chain load?
Some info on the clutch system I've been using:
Trike weight: 197lb
Engine Mods: 212 Predator, bored carb, springs, jetted, billet flywheel, timing +3 degrees
Drivetrain: 12" wheels, 12t magnum clutch w/heavy shoe, 64t sprocket
Pic of trike.
Pic of what I'm trying to do.
Trike weight: 197lb
Pic of trike.
