Got some more work done over the weekend. Ran the cable for brake and accelerator. I used large lock washers as they are thick and won't chafe the cables. One behind the fork and the other at the front of the engine plate.
I also got the drum brake set up. Working on mounting the seat.
I've had to make a lot of modifications to the frame due to the larger motor. It originally had a scrub brake but the foot peg was under the blower housing. I cut it off and went with the drum brake.
I had to put foot pegs in the front so new mounting tabs had to be welded on. I used part of the scrub brake arm for the kick stand. I got it working on the left side but when I mounted the engine, the whole bike wanted to fall to the right. I spent about an hour welding on a new bracket on the right and cutting the one off the left.
I did try to fire the engine again but it wouldn't light. I pulled apart the carb and found all kinds of junk plugging it up. It figures as it's been sitting for over 20 years. Rebuild kit is on order.
If the parts come in time, I may have a running bike this weekend. I'll work out the bugs and then tear it down for the powder coating.
Bob
