Heat the block by running it, or using a heat gun, or gently with a propane torch. Melt beeswax around the water pipe so it penetrates the threaded joint. Beeswax is thin when melted, and breaks down the electrolytic bond between block and pipe. Unscrew pipe. Old air cooled machine shop trick learned from Leadhead.
