i have a 5.5 Coleman engine (Honda Clone) off of a presser washer and i put it on my go kart and it wont run unless almost completely on choke and the carb leaks out gas when not running it like over flows or something
if it's leaking gas there's a good chance the float is stuck open some. it sounds like you need to take the carb apart and give it a good cleaning (especially since it was a used engine).
yah i took it apart to see if it was stuck and it wasnt stuck. I put it back together and it ran so i drove it and then it died and it was leaking like a mother.
it is leaking out of the top of the carb i will try to get pics
