Ok made some good progress, Got my sprocket back with the holes cut in so you can see the wheel behind it. Now I can get my wheels back together. Got the frame all cleaned up and ready for paint. I'm still in the process of getting the bars done. I needed a new muffler and found the chrome bent one today for $2.00 at the flea market. I was pretty happy about that. I threw the frame up on the bench and set the engine in just to check the fit. I think I'm F--ked, That H-40 is way to big. I forgot about the angled frame. It WILL NOT bolt on to the original plate set up. If I can Modify something It may go, possibly center it and drill new holes. But If I hit some thing and slide forward I'm going to have a " SACTASTROPHY" I'll have to get the back wheel on and see if I have enough shaft to line up the clutch (The pulley on there is just left overs) If I move it back and center it. I dont want to drill the plate but I'd love to use that Tec 4hp.
Option 2.... Small BS, Thats an old one with the horse hair oil filled air filter (I'll probably have to put a flat breather on it instead.) I dont even know what HP it is but it looks small. I can post the numbers if some one knows how to read them.
The 4HP tec is Running the Briggs isnt (at the moment but does run ) I'm running out of time what do you guys think any suggestions?
