Color Matching through Layering--Clutch Guard
Here's the process I used to color match the clutch guard to Copperhead powder coat. Using candy or anodized colors helps but not always necessary (and you can use Testor's Model Spray paints). The key is to apply each coat lightly and about 5 minutes apart. Each coat is applied as the previous starts to flash.
1) Base coat of GM Metallic Gold--
2) Followed by overspray of Metallic Groundcoat (Duplicolor)--
3) A light coat of Anodized Copper (VHT)--
4) First coat of Anodized Red (Duplicolor)--
5) Another mist coat of Metallic Gold--
6) Misting of Metallic Ground Coat--
7) Several Coats of Anodized Red to build to desired color depth--
8) Final product--
And here's the new TAV Guard for Copperhead (my Gilson)--
